It is currently Sun Oct 22, 2017 12:58 pm
 Post subject: Toyuki Swift R
PostPosted: Tue Sep 27, 2016 4:36 pm
IDK where to put this thread, so
Hey guys, I have here the first MK5? that will be equipped with a Toyota 4age blacktop 20 valve.
Currently has S13 coilovers from J2 in it. Doesn't have the shock and spring setup in the rear anymore. Will be rolling on some JNC wheels wrapped with Bridgestone Potenza RE11's
Started the project this week. Dropped the crappy 1.3 engine last night and test fitted the 4age.
[URL=http://s1287.photobucket.com/user/hairymonkey019/media/Anything%20Car%20Related/HiN/Swift/62b8bdeb-bf05-4ae7-a5ab-c14eb9b10a29_zpsf9c0fabg.jpg.html]Image
Image[/URL]
 Post subject: Re: Toyuki Swift R
PostPosted: Tue Sep 27, 2016 6:22 pm
Cool make sure to post lost of updates and pics
___________________
89 Swift gti
PostPosted: Tue Sep 27, 2016 6:50 pm
Oh, I will :D
Also, if anyone can tell me where to get a cheap steering wheel hub for the thing, that would be awesome. I want to ditch the crappy steering wheel and airbag from the car, or if anyone has a used one that's compatible with the car, even better. The idea is a budget build, but still fun af to swing around. =)
would this work?
http://www.ebay.com/itm/Kylin-STEERING- ... s1&vxp=mtr
Last edited by hairymonkey019 on Tue Sep 27, 2016 6:57 pm, edited 1 time in total.
PostPosted: Tue Sep 27, 2016 6:57 pm
Interesting project!
S13 coilover as in nissan silvia?
2003-EVO7 GT-A
PostPosted: Tue Sep 27, 2016 6:58 pm
Yes sir! Modified the car a bit and the coilover mounting brackets.
PostPosted: Tue Sep 27, 2016 7:06 pm
Been done. first one posted with a 4age 20 valve was posted 2010. But its cool swap. It was on http://WWW.TUNEDCARS.ORG i remember it was on a 1997 swift GT.
PostPosted: Wed Sep 28, 2016 12:33 am
Awesome build. Keep up the pictures and the narrative. These seem to work well with us monkeys. Just remember to feed us every now and then.
RP91gt wrote:
I remember it was on a 1997 swift GT.
What in the hell is that? Australia?
clinty wrote:
pacapo wrote:
JVS wrote:
1996 Geo Metro (Stocker)
PostPosted: Wed Sep 28, 2016 3:54 am
Pics, or it didn't happen. :razz:
Picture of rear suspension. This thing is stiff af with these coilovers.
PostPosted: Wed Sep 28, 2016 5:51 pm
Awesome.
Can you go into the details a bit of what you meant by modifiying the car? Maybe these can be made to fit the mk2 mk3 chassis.
I don't think I have seen this before.
Thank you.
2003-EVO7 GT-A
PostPosted: Tue Oct 04, 2016 11:41 pm
The same day we pulled the shitty 1.3 out, I was able to find a buyer for that motor and trans lol.
Engine can now sit in the bay without a jack or jackstands!!!! It was only supposed to take a couple hours, but took the whole day haha. This thing will be VERY EASY to service.
Now, all the measuring and tedious work begins.
Pictures include the sawed off light weight crank pulley, modified motor mounts, and good stuff.
Next week we should be test starting it before doing all the measuring.
PostPosted: Thu Oct 13, 2016 1:27 am
Partially gutted and have a Momo steering wheel and NRG quick release ready to be installed. Waiting on hub to come in.
PostPosted: Tue Nov 01, 2016 2:13 am
Finally got the car started!
All down hill from here. My boy was able to eliminate what wasn't needed off the harnesses, got the shifter to work, shortened and lengthened every single wire. All the plugs and wiring has been figured out. Everything at this point will be mechanical, cutting, and welding things.
https://www.youtube.com/watch?v=-oTht2btXZ0
PostPosted: Tue Nov 01, 2016 2:58 am
Nice... you never stop to impressive me! A lot of things are new to me!
btw the coolant (and air system too) should be installing and running properly... or it made me cringe.
PostPosted: Wed Nov 02, 2016 6:32 pm
not sure why it isn't showing up. why does link not show as an actual video???
PostPosted: Wed Nov 02, 2016 8:30 pm
It works for me. :?
PostPosted: Thu Nov 03, 2016 12:46 am
Very impressive work so far.
I am very interested when you finish to hear how well your engine and transmission mounts perform, as the orientation of the left and right mounts are exactly 90 degrees different than the stock Suzuki mount orientation. I've always wondered whether mount setup can make a difference in controlling torque steer.
PostPosted: Thu Nov 03, 2016 3:03 am
I don't think he will find out . Those will not last long enough for that , especially that transmission mount.
PostPosted: Thu Nov 03, 2016 7:08 pm
The mount orientation is the same as Toyota's original configuration. Whdo you think it wont be strong enough in this Suzuki? Not enough gusseting on the frame rails maybe??
PostPosted: Fri Nov 04, 2016 5:05 pm
Well , why would manufacturers make such elaborate engine mounts brackets if couple of lengths of Home Depot mild steel with couple of not so good butt welds stuck to sheet metal would work =)
PostPosted: Fri Nov 04, 2016 6:30 pm
Link to motor mounts for 4age to Suzuki Swift body.
PostPosted: Tue Dec 13, 2016 1:52 pm
Updates:
I don't have pictures of the shifter mount, but it was raised about 4"-5" and can be unbolted from the car to drop it back to stock position. (everything on this car will be made to be removable and easily accessible.
Finally the 2 wiring harnesses have been combine, shortened, lengthened, and loomed together. Unnecessary connectors were also removed, so the harness looks factory as it should.
Imageadult image
Imagefree upload
Imagepicture share
Imageimage hosting
Pretty much got everything mocked up. Motor mount has been reinforced (forgot to take a picture). Radiator is pretty much ready, just need one hose to complete it and get a new overflow tank. Oil cooler location has been established (the blue thing). Location of the battery has also been established, just need the tray and install. Need to find a spot for the clutch master cylinder, because the swift never had one. Gonna plug up a few vacuum lines, throw on a filter for the crankcase vent, another filter for the Idle air control. Once all the hoses are connected the harness is going back in. My friend will also be making a rear torque mount, so engine movement should be very minimal. Lastly, my friend will be making the exhaust.
All around, the engine bay is going to be really clean and easy to work on. If the motor and trans has to come out, we can easily drop it since it doesn't have a sub frame.
Hopefully we'll have it on the road by next week or the week after.
Imagephoto hosting
Imageimage sharing sites
Imageuploading images
