It is currently Fri Oct 20, 2017 7:46 pm
PostPosted: Tue Dec 13, 2016 8:21 am
Good morning all.
Straight to the point. I am unable to find that forward bushing of the front control arm. (Of course, if I had $$$ I would buy it online, obviously but since living in socialism then... you know).
http://www.moog-suspension-parts.com/moog-k200312 Image
The help I need from you guys is the following:
* Dimensions or measurements of the bushing, or...
* What other car (besides the obvious geo metro, sprint, firefly, or any swift / metro clones) uses something that matches the inner diameter of the bushing and the lenght. Doesn´t matter if the rubber part is wider, I can cut and custom fit anyways.[/list]
For example, the Geo Prizm (or Toyota Corolla) seems to use something quite close, but I will go out (once again) to the parts stores around to see if they match. Image
Suzuki Swift GLX - 1.6L - SOCH 16 valves - Carb Model
Mods: Auto Tranny Cooler
Weber 32/36 kit from Toyota Tercel
2 row aluminiun radiator
PostPosted: Wed Dec 14, 2016 4:39 pm
This should help.
This is for Whiteline's aftermarket bushing that has a different design, but the dimensions are there. Also, whiteline cross references this part with a Subaru XT, which is just about as obscure, but maybe you could try that route.
PostPosted: Wed Dec 14, 2016 4:45 pm
Whoops, I see you are looking for a part to fit 1995-2000, so that might not be right.
PostPosted: Wed Dec 14, 2016 5:40 pm
OP is from Venezuela so the Swift version is same as mk3
PostPosted: Thu Dec 15, 2016 2:17 am
Ah, well then, the link he posted is for the wrong part =)
