It is currently Wed Oct 18, 2017 10:20 pm
PostPosted: Fri Jul 17, 2015 12:49 pm
Hi everyone. Im looking for gti reviews of this cam setup. Ive watched a few vids of idling gtis. Im guessing the power comes in hard at around 4000rpm, but what happens below that? How does it drive in traffic and at low speeds? Im considering getting these for my street sleeper swift gti. All those with experience please share.
PostPosted: Fri Jul 17, 2015 3:40 pm
I have those in my 89 gti, as well as a ''sandros'' chip.
you can sure tell at idle that they are in there...
I think I lost a little at the lower end, but over 3500 it pulls, really wakes the car up over 4,000.....8600rpm redline really easy to hit!
runs smooth on the highway at 3-3500 rpm in 5th, can moderately accelerate without shifting...but drop it to 4th (or 3rd :shock: ) and its off like a shot!
makes everybody look when its running, wife still thinks its broken by the way it idles :-P
and still decent on fuel! still getting 40+ mpg with these cams/ chip setup.
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Fri Jul 17, 2015 6:12 pm
have a set in my 88 g13b chevy sprint, loose a lot of 0-4000 but the gain over that is excellent, not for traffic jams but it can be daily driven (just push harder on the right pedal to go off a stop or a light)
i suggest to do the 4.39 final drive swap to help and take advantage of the new powerband
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Sat Jul 25, 2015 4:00 pm
The best cams for the GTi!
The engine will become like a monster between 4k rpm and 4.5k rpm. I have mine dialed in. I think I posted my settings in the track talk section.
Below 4k feels normal to me.
2003-EVO7 GT-A
PostPosted: Thu Dec 01, 2016 5:50 pm
How do these cams hold up over time? Are they very reliable as in would go 100k miles or more? Is there anybody out there that have been running these cams for awhile?
Black 1989 Swift GTi 5 speed
Dark blue 1994 Swift sedan 5 speed
Green 1993 xfi metro 5 speed
PostPosted: Fri Dec 02, 2016 12:22 pm
Theyre ground on OEM cores, so they'll last as long as stock cams, 100's of thousands of km's
PostPosted: Tue Jan 31, 2017 7:46 pm
Will they do any good with a turbo at 8-10 pounds ?
Ken.......
PostPosted: Tue Jan 31, 2017 11:01 pm
Definitely.
PostPosted: Thu Feb 09, 2017 9:01 am
Suprf1y, what about with nitrous? Same question for the 210/340 cams.
PostPosted: Tue Feb 21, 2017 2:21 pm
So - where can I buy them? ;)
Suzuki Swift GTi mk2 - 131hp and 127Nm
PostPosted: Mon Mar 13, 2017 2:29 pm
3tech.
2003-EVO7 GT-A
