It is currently Fri Oct 20, 2017 3:45 pm
PostPosted: Fri Feb 17, 2017 4:40 pm
Tore my motor apart to freshen it up and noticed a deep groove where the rear main seal sits on the crank. I found a Redi-Sleeve for the front seal, but haven't found one for the rear. Anyone know if they make one for the rear on a G13B?
-Dave
93' Suzuki Swift Gt Turbo
PostPosted: Fri Feb 17, 2017 6:09 pm
If you have the shaft diameter you should be able to find one on a sleeve mfg website. I needed one for a custom buggy transmission output and that's how I found it.i can't recall where but should be easy enough to search. However I made a spacer to move the seal just enough to ride on a fresh area and that worked for me.
PostPosted: Fri Feb 17, 2017 9:50 pm
That's not a bad idea, I could probably move the new one in a tad to get off the groove. Thanks!
PostPosted: Sun Mar 12, 2017 11:20 am
I ended up finding a sleeve for the front and rear seal surfaces. The front is redi-sleeve p/n: 99128. It's a direct with with the exception that you have to grind down the sleeve flare where the oil pump keys line up. I used SKF speedi sleeve p/n: 99266 for the rear. It was longer than needed, so I had to grind it down to fit. The front and rear seals now have a nice smooth surface ride on.
