It is currently Sat Oct 21, 2017 3:47 pm
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Nov 03, 2016 12:49 am
Hi boy's and girl's,
I had a few problems with the plastic I used to print the ecu box.
The cylinder head is back.
and only about half way on the body work.
Sorry I did tell you about the ecu, it's a Speeduino v4.2 ,
it's simular to the megasquirt and uses the same tuning software, but uses a Arduino mega 2560 board for it's brain.
it's cost $200au by the time you have gotten everything for the computer, external sensors are extra.
PostPosted: Thu Nov 17, 2016 9:28 am
Hello boy's and girl's,
I've made some progress in the body work.
After block sanding
After 2nd layer of primer
After 2nd layer of paint
PostPosted: Fri Nov 18, 2016 11:37 am
Dang! Coming along nicely!
PostPosted: Sun Nov 20, 2016 1:23 am
hello boy's and girl's,
the painting is finished :yeahyeah
after the masking is removed and the first look :thumbsup:
PostPosted: Mon Dec 05, 2016 10:52 pm
The car is back together,
The bolck has been prepped.
And i have printed a new box for the computer
PostPosted: Wed Dec 14, 2016 9:30 am
Hello again boy's and girl's,
thx SnowFish :)
More progress has been made on the motor as I wait for parts to arrive,
I have drilled and taped the holes for the oil squirt's
The SR20DET oil squirt's are bolted in place.
And lastly I have relocated the oil pressure switch.
PostPosted: Thu Dec 22, 2016 7:35 am
The parts i was waiting on have turnned up, but no
gaskets for the oil pump or rear main housing.
so i went to the local parts store and got some
gasket papper and cut my own.
This connecting rod is a splash feed style, so that is was the reason for the oil squirt's.
PostPosted: Mon Dec 26, 2016 12:58 am
Hello boy's and gilr's,
This is the progress on the motor.
Carnk and pistons installed
The cylinder head is on, along with water pump, alternator, coils and thermostat housing
Set the motor timing
And lastly the inlet manifold is on
PostPosted: Tue Dec 27, 2016 8:17 pm
Lots of great progress! Your engine assembly is very clean! (Almost too clean.. as in.. camshaft thirsting for some assembly lube!) =)
:-P :-P
PostPosted: Wed Dec 28, 2016 6:27 am
suzukitom the lube is all good as it has grease and oil for lube :thumbsup: ,
More progress has been made,
The Air temp sensor has been installed, it's from some random
car from the wreackers.
Old motor is out and preaperation has to be done.
PostPosted: Sun Jan 01, 2017 3:17 pm
the fuel system is been prepared,
PostPosted: Thu Jan 05, 2017 2:30 am
The crank sensor is mocked up
Crank sensor finished up
Motor and gearbox back in
Chassis and sensor clearence
PostPosted: Thu Jan 05, 2017 6:36 pm
fe dad, is the crank sensor using that screw head as a trigger point? does that provide adequate data resolution for your engine management?
i do my crank triggers differently, mostly using a 36-1 toothed trigger wheel that gives me a data point for every 10 degrees of crank rotation, 5 degrees if i sense rising and falling edges. i also ditched v/r sensors altogether, opting for the precision and signal integrity of hall effect devices.
i can explain in detail if you are interested but won't bore you if you aren't. :lol:
PostPosted: Tue Jan 10, 2017 2:14 am
Hi again boy's and girl's,
The exhaust is connected, it's ugly but it works
Air cleaner installed
Rear sway bar installed.
Hello t3 ragtop, Yes and Yes, a 36/ -1 is preferred or optical, but i'm only using 4/ -1 and parts I have laying around,
as i'm on a time crunch :)
The car will be staying Na for a few months, not planed but has to be.
PostPosted: Wed Jan 25, 2017 12:27 am
just up to the tedious part of wiring the engine :)
test fit of the harness
PostPosted: Fri Feb 10, 2017 11:28 pm
I've been cheeking and recheeking my wiring.
This was a test fit on ide conection.
This was the actual plugs used.
All of the harnesses complte.
I'm starting to looking in to my tuning options.
I still have to wire it into the car, then the fun begins :yeahyeah
PostPosted: Wed Mar 01, 2017 12:05 am
hello again girl's and boy's,
progress has been made, and a big set back.
I had to test the extremes of the sensor
I had a problem with the vr conditioner witch damaged the computer
so I had to go to the backup computer
Blue tooth is setup up and connecting to the tablet
i'm still working on setting up the efi. :yeahyeah
PostPosted: Wed Mar 08, 2017 1:52 am
Well things have progressed slower than expected,
after a few wiring problems, and setting isuess with
the tune, i still haven't got it to run yet.
After a few try's at starting the engine, i have only been
able to get a few back fires so far, this is a problem as
I hadn't conected the fuel injectors. So it look's like
I have to get the injectors serviced or replace them?
So that is were the car sits today.
I'll keep you posted :)
PostPosted: Thu Mar 30, 2017 1:55 pm
Love the build, glad you resprayed it in silver. Digging the front lip. I wish I was good at fiberglass work so I could make one. Looking forward to updates.
'94 Metro LSi 'Green Machine'
'94 RHD (Totaled)
Vail, AZ
PostPosted: Wed Apr 05, 2017 3:36 am
Hello again Boy's and Girl's,
Well the story begins with failures, starting with the blue tooth failing on the laptop,
then it was Usb cables i was using (x3), after that the arduino mega 2560 boards started to fail
one by one, this wasn't the biggest problem after the 3rd failed, i had to order more,
later that night i shut down the laptop, only to have it not turn back on at all, it die also.
I also discovered that the Usb oscilloscope had die as well.
The laptop failing was the biggest set back, as i had not backed up the tune in a week, this means that
i was back to square one and had to start again.
A week later i was able to buy a new laptop and start installing software and registration's only to find out
that i was at my limit of software install's, so i contacted the software company and explained my
issue and they fixed it up the registration for the software. In the mean time i had discovered the my
map sensor was malfunctioning so more parts had to be ordered and installed.
Yesterday i was able to start tuning again, so it will run soon.
I have installed a igniter to help with the crank signal and some new relay's and battery.
Thx 94 RHD Metro,
I will say give the fiber glass work ago, it's not all that hard.
It took more time getting the basic shape and then body working it for paint.
the sooner you start the sooner you will become a master in it :thumbsup:
PostPosted: Sat Apr 08, 2017 10:08 pm
:cheers: :yeahyeah :cheers: It Start's :cheers: :yeahyeah :cheers: :)
I'll start tuning it tomorrow :yeahyeah
