It is currently Tue Feb 20, 2018 4:17 pm
 Post subject: Cam journal cap bolts
PostPosted: Sat May 06, 2017 8:58 am
Anybody have a couple G13B DOHC cam cap bolts laying around they want to sell? Shipping to 68066, thanks!
93' Suzuki Swift Gt Turbo
PostPosted: Sat May 06, 2017 2:25 pm
I have a bunch, or at least I should have. They won't likely match up, but there is a way to make them work
PostPosted: Sat May 06, 2017 8:15 pm
The bolts aren't standard size? I don't need caps, just the hardware. I'll take two off your hands.
PostPosted: Sun May 07, 2017 5:14 pm
The aren't anything special are they? M6 x 1.0 thread in whatever length needed. Should be able to match them up at a local hardware or autoparts place.
PostPosted: Sun May 07, 2017 6:06 pm
I misunderstood, didn't see bolts
PostPosted: Sun May 07, 2017 9:19 pm
It's ok if you can't read real good. You're still pretty handy with crunching cam numbers =)
PostPosted: Wed May 10, 2017 11:40 pm
I have bolts that would work, but i'd like to keep them OEM. Still looking, please let me know if there are two available.
PostPosted: Thu May 11, 2017 5:03 pm
good grief man!
they are under the valve cover so nobody can see them and i promise i won't tell anybody. =)
PostPosted: Wed Jun 28, 2017 6:08 am
I got it
PostPosted: Wed Jun 28, 2017 2:25 pm
Many Suzuki engines use same bolts , Metro , Vitara come to mind . Plenty of them in the junkyards. Thats what I did when I couldnt find mine
PostPosted: Wed Jun 28, 2017 2:29 pm
Could you share that way of making them work , other then line boring them with the cylinder head .I just stuck ones that I have on the cylinder head and they seem to be doing OK . Just had 200 mile oil change after the rebuild and didn't see any metal flakes in the oil whatsoever
PostPosted: Wed Jun 28, 2017 4:19 pm
Open up the holes that fit over the dowels, or in severe cases remove the dowels, then check if they center over the bottom part of the journal.
PostPosted: Thu Jun 29, 2017 1:26 pm
For what it's worth, the newer aveo 1.6 engines don't have aligning dowels and they seem to work fine and never have any significant wear up there on the head or cap. Obviously dowels add that certain level of precision alignment, but it does appear that it's one of those things that works without, as the aveo heads have shown. Very similar setup, cap size, bolts, lifter style etc.
