It is currently Thu Feb 22, 2018 8:36 am
PostPosted: Tue Aug 01, 2017 11:11 pm
price are in usd $ will work on picture soon, shipping at buyer expense
all parts are for G13B DOHC unless otherwise specified.
jdm cultus f6 ecu 220$
2 pair of 8.5mm lift camshaft 200$ each (the 2 sets are hollow)
custom performance clutch dual diaphragm pressure plate with 4puck sprung hub ceramic disc 140$
lightened front damper pulley (A/C part removed on a lathe) 40$
2 valve covers for mk2 1 painted black 1 painted yellow 40$ each
distributor 30$
used stock pistons 20$ each
top timming belt cover 20$
flywheels 40$ each
stock ecus f3 i2 80$ each
60mm nissan throttle body with mk2 intake 80$ (need work for cable bracket and TPS, previous owner started but did not finish)
engine block heaters (surface bolted) 20$ each
ignition coil, near new condition 40$
bare intake manifolds 30$
4.10 final drive 80$
1 GTI horn cap 50$
air intake tubes 20$
various GT parts i have everithing, box full of spare parts
for megasquirt or standalone
adjustable fuel pressure regulator no name (copy of aeromotive) 50$
mitsubishi outlander v6 2009 injectors 30$/6
ford f150 2010 5.4 injectors 30$/4
toyota corolla 2006 blue injectors 20$/4
1990 eagle talon turbo fuel pump 40$
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Wed Aug 02, 2017 8:42 pm
Pm sent
Find me on Facebook
My eBay link
Check out my videos
PostPosted: Sun Aug 06, 2017 5:46 pm
You got a new PM
PostPosted: Mon Aug 07, 2017 4:57 am
Hi guys, i'm new here, shortly I bought a 98 justy with engine g13bb, at home I have a g16b derived from a vitara, my question is that I have to make modifications to mount that engine, apologize for my bad english i come from croatia :-P
สมัครบาคาร่า
PostPosted: Tue Aug 08, 2017 12:04 pm
price of the gauge lowered
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Fri Aug 18, 2017 12:30 pm
removed some sold parts, thank you guys
feel free to make offers, it may be yes... or no in the worst case :D
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Sun Aug 20, 2017 8:22 pm
Turbo manifold in first pic?
Do you have the engine harness for the jdm ecu? (Jdm harness has knock sensor wiring build in)
2003-EVO7 GT-A
PostPosted: Mon Aug 21, 2017 12:06 pm
manifold not for sale,
no jdm wiring harness either, sorry
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Sun Aug 27, 2017 3:06 pm
Are you selling the gage pod also, or just the gages?
89 Swift GS/T3/rear disc swap
88 Forsa Turbo, 14psi rust bucket, DD
Or as my friends like to call it "The Foreskin"
PostPosted: Mon Aug 28, 2017 12:00 pm
gauge pod already sold sorry
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Wed Sep 06, 2017 2:10 pm
price of the camshaft lowered
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Thu Sep 07, 2017 7:57 pm
Do you have any usable DOHC heads for sale?
PostPosted: Fri Sep 08, 2017 9:08 am
not so much so i keep them for spares sorry
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Mon Sep 11, 2017 7:06 pm
lowered some prices
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Tue Sep 19, 2017 4:51 pm
Interested in your coils and prob the injectors, are the coils smart coils? Any pics? And 30usd for the set correct?
PostPosted: Sun Oct 01, 2017 12:28 pm
added swaybar and 3cyl cluster with tach
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Sun Nov 26, 2017 10:45 pm
Any of this stuff still available? Im looking for a stock exhaust cam for my 89 Swift GTi. Seems like private messages arent working for me though.
PostPosted: Mon Nov 27, 2017 10:08 am
site having an issue for Pm and new threads
sure i have stock exaust cams 40$ + shippign
give my your postal code i will check shipping prices
you can PM just ignore the error code, the message will be delivered even with error mesage
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Mon Nov 27, 2017 12:43 pm
Ok PM sent. Hopefully you received it
PostPosted: Sun Dec 03, 2017 9:40 pm
3cyl cluster with tach?? $??? Still available?
PostPosted: Mon Dec 04, 2017 8:07 am
yes send me your adress via PM i will invoice you the total price
thank you
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Sun Jan 14, 2018 7:36 am
Apparently PM isnt working but the shipping zipcode is 00685. If you can give me a quote ill appreciate it
PostPosted: Wed Jan 17, 2018 3:55 pm
What is your current inventory?
clinty wrote:
pacapo wrote:
JVS wrote:
PostPosted: Thu Jan 18, 2018 1:03 pm
first post updated 18jan2018
if anything is needed but not listed, ask
thank you
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Wed Jan 31, 2018 6:05 pm
Hi there! I am looking for a stock exhaust cam for dohc. Also I am interested in the distributor if you still have it. Shipping zip code is 45893. Tried a PM, but I don't know if it went. Sorry if I double posted. Thanks for your time.
Users browsing this forum: Flipper, marcos and 2 guests
