It is currently Wed Jan 24, 2018 7:03 am
PostPosted: Sun Oct 15, 2017 9:34 pm
Can I use 95+ control arms on all 4 corners for my Suzuki Swift GTi to widen the stance of the car for better Cornering. I searched around and found nothing useful so I thought I'd just ask.
Black 1989 Swift GTi 5 speed
Dark blue 1994 Swift sedan 5 speed
Green 1993 xfi metro 5 speed
PostPosted: Sun Oct 15, 2017 10:07 pm
I asked that question 2 years ago...
you could but not good idea so you better use 89-94 suspension part.
PostPosted: Mon Oct 16, 2017 9:05 am
i have run my 2000 swift with rear disc brake conversion, was giving 2.5 deg negative camber on the rear and on the front i don't remember
you can do it, just make sure you do wheel alignement and keep in mind you may need to swap rear toe arms to make sure you can reach the right ajustement (don't know if it's required since i was using custom toe arms)
for the front it make the wheel more wide than a 89-94 i don't know if the axle can take the "stretch" if not you can shim a little between axle and bearing but may be " for offroad use only " :lol:
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
