It is currently Sat Oct 21, 2017 2:04 am
PostPosted: Mon Nov 15, 2004 5:08 am
Links to threads concerning electrical topics:
General:
Factory service manual electrical sections
Fuse Panel Cover (fuse identification)
How to trace wires
How to test for a slow battery drain
How to fix rotten wires
How to repair switch contacts
Battery/starter:
Inconsistent voltage at starter - starter problems
Nippondenso starter contact replacement
Clutch safety switch
Door Switch Failure FAQ (persistant parasitic voltage drains)
quick-release battery post connector
Intermittent main power glitch
Lighting:
Headlight relay mod with pics
Strike the lightning! (rewire headlights with relays)
Metro headlight repair with relays
Repairing malfunctioning headlight wiring 1 (HIGH/LOW switch contacts)
Repairing malfunctioning headlight wiring 2 (image links are all dead)
Repairing malfunctioning headlight wiring 3 (headlight ground fix)
DRL tech with disabling info (MK2/MK3)
MK5 DRL info
MK4 DRL disabling info
DRL disabling 1 (image links are all dead)
DRL disabling 2 (image links are all dead)
How to aim headlights
LED auxillary brake light replacement
Foglight circuit
Interior light dimmer repair/bypass
How to connect gauges to the dimmer circuit
Security:
Security Systems
Blinking alarm LED
'Vert security
Sensor/Ignition/ECU:
Recalibrating a 4 cylinder tach for 3 cylinder operation
Lessons learned from MSD install
Apexi wiring FAQ
Chip and ECU theory....
CO adjustment screw and CHIPS (ECU circuitry comparisons)
Audio knock sensor install
GTi specific:
All GTi electrial links are now located in the GTi Index (click and scroll down to Electrical):
http://www.teamswift.net/viewtopic.php?t=6700&highlight=Electrical:
MK1:
1988 M/T full vehicle wiring diagram
PostPosted: Tue Jul 18, 2006 6:44 pm
hey, thanks for postin all that stuff man, it has really helped me out. imaginary karma for you :)
Lihtan you da man. :yeahyeah
PostPosted: Sun Dec 31, 2006 5:33 pm
I love this thread. I have been doing in depth mega-time consuming searches when it was all right here.
BIG Karma to you!
PostPosted: Sat Oct 20, 2007 11:47 am
yes thanks lithans .. it really help me when my car dead at highway, the fuel pump connector worn out.. so i cut the wire end to end and connect with a normal electrical wire connector..
regards kasut
ka_sut@yahoo.co.uk
g13B user.
PostPosted: Tue May 06, 2008 8:45 pm
been searching this forum for 4 days and finally found what i was looking for
viewtopic.php?t=35536 HURRAY!!!
95 Geo Lsi 5spd 2dr hatch
93 Geo 5spd 4dr hatch
90 Geo Lsi 5spd 2dr hatch
90 Geo Lsi Auto 4dr hatch
96 Geo Tracker 4x4 Hard top
numerous parts cars
