It is currently Tue Feb 20, 2018 9:12 am
 Post subject: losing coolant
PostPosted: Tue Dec 14, 2004 9:04 am
'91 metro, stock
i seem to be losing coolant. not quickly, no puddles (so the radiator seems OK) and no white smoke from the back (which is good).
what can i do to try to figure out where the problem is?
'91 Metro Convertable
'93 Metro Hatchback
PostPosted: Tue Dec 14, 2004 10:42 am
mine was doing the same thing and it turned out the water pump was bad and it was loosing coolent out the bottom weep hole.
PostPosted: Tue Dec 14, 2004 1:33 pm
Check for old cracked hoses, and take a look at your heater core for leaks too.
PostPosted: Tue Dec 14, 2004 4:01 pm
if the heater core has pinholes, it can blow in a fine aerosol of air/antifreeze into the interior when you have the defogger fan switched on. antifreeze can have a distinctive smell, and can leave a sticky residue on your windows, and make it seem like your defogger is working in reverse. ie. fogging your windsheild.
also check your rad cap seal
 Post subject: Re: losing coolant
PostPosted: Wed Dec 15, 2004 12:01 am
jakeOSX-2 wrote:
'91 metro, stock
Mine was doing this too. Front of radiator fins were slightly green - think I had the tiniest pinhole. Replaced radiator - still lost coolant over time.
Eventually the waterpump started leaking badly, especially when cooled down (pressure actually helps it's seal work better). After replacing the water pump I no longer have an unexplained coolant loss.
- MPGuino
