It is currently Fri Feb 23, 2018 11:38 pm
 Post subject: MK1 Sport Spring
PostPosted: Thu Aug 08, 2002 8:51 pm
Where can i get the front sport spring for the Mk1 <br><br>any info...<br><br>also are they other car's spring that can fit the Mk1<br><br>Some help is greatly appreciated. <p></p><i></i>
 Post subject: Re: MK1 Sport Spring
PostPosted: Wed Aug 14, 2002 4:38 pm
Senior Member
Most springmakers/suppliers wil be able to either make or supply a spring for your car...<br><br>King Springs here in Australia (sorry no contact details for you but a search would turn some up) have gear available for SA GTi's... <p></p><i></i>
PostPosted: Mon Dec 20, 2004 2:49 am
http://www.kingsprings.com/
part# KSFL-12
no distributors listed in the US or Canada 'tho
PostPosted: Mon Dec 20, 2004 4:03 am
Senior Member
I got Kings on mine front and rear and KYB Shocks, I'll rustle up the part numbers tomorrow.
Even the missus usedto comment on its road handling....
PostPosted: Wed Dec 29, 2004 8:43 pm
found some more updates, suprf1y suggested the <a href="http://www.apexsprings.com">apex springs</a> he uses, they are no longer being imported into north america 'tho :P
Swift all - 1986-89 - AE33 - 35mm part# 140-1000
i've emailed apex to see if we can get any sort of club discount or even just ordering them direct ... i'll post more when i hear back :)
alt link for <a href="http://www.apexsuspension.com/">apex springs</a>
PostPosted: Thu Dec 30, 2004 12:37 pm
spax also makes lowering springs, not sure if anyone sells their stuff in the US, highly progressive springs.
part# SO37006 35mm drop
mk2-3 cars use part# SO37005 40mm drop
PostPosted: Fri Jun 17, 2005 3:30 am
I bought Apex from http://www.khmotorsport.se/ (Sweden). 1395 SKR that will make $190.
I think they are nice.
Only for race. Swift GTi 1987.
PostPosted: Thu Feb 23, 2006 4:30 pm
I have a set of brand new springs that lower by 35mm. They are exactly the same as the red resin coated ones in the above picture. They are for the mk1 swift. I am willing to post international if you make me a reasonable offer. :)
 Post subject: Re:
PostPosted: Wed Jun 16, 2010 11:27 am
Do they fit MK2 swift GTi....? :huh:
I found on one site that part. nr. 140-2000 is for MK2 so I assume that they aren't compatible or they are..?
......................................................................Suzy.....
 Post subject: Re: Re:
PostPosted: Wed Jun 16, 2010 1:03 pm
http://www.paw.ch/100/con_liste.asp?pro ... tPageNext=
translate the site on english and have fun buying 60/40mm lowering lowering springs ;)
or just conact them @ email they can speak english to
by
That's 30 minutes away? I'm there in 10!
------> http://www.cardomain.com/ride/2496630 <------
------> http://www.youtube.com/results?search_q ... rch=Search <------
PostPosted: Wed Jun 16, 2010 5:26 pm
No they don't fit your car. They fit the car that is in the MTS reply. The dates are normally listed as 1986 ~ 1988 - the model changed late in 1988 for the 1989 model year.
I see the springs in front or rear pairs on ebay from time to time. You have to watch for them. Unlikely to see more than 40mm drop ebay spring these days. To drop more than 40mm, you would have to use short shocks or coilovers on the front and short shocks on the rear.
PostPosted: Thu Jun 17, 2010 4:36 am
jm wrote:
no short shoks on the rear but at the front 2mm shorter is a must do when 60mm springs are mountet!
you can olso buy some 40mm springs and press it downt to 60mm, but im no fan from this work^^
there is a firm called http://www.kw-suspensions.eu/int/ ant they have full adjustible threaded suspension oder coil-over kit but the price is very hot ;) 3500$$$ with out shipping... but you can tell the what you want and they let your wishes come true haha
by
EDIT: i ment of corse 20mm shorter at the front shock :razz:
PostPosted: Thu Jun 17, 2010 4:37 am
Too bad they don't fit... :(
I found this set for 56€ (~70 USD)...
PostPosted: Wed Jun 23, 2010 7:13 am
The Apex springs (part# 140-1000) are listed for the following models: GL, GLX, GXi, GTi chassis: AA33 / 43 / 53.
I have an 86 Suzuki Swift GS with an AA51 chassis. The rear springs are leaf springs. Will the Apex springs fit my car?
If not, perhaps someone know of some other springs that will fit my car?
Thanks!
