It is currently Mon Feb 19, 2018 11:26 am
PostPosted: Tue Mar 22, 2005 8:11 pm
HI, i have a 1994 geo metro xfi, and i just bought the crossed drilled rotors and new brake pads. i never taken of the brakes before. and the hub won't budge. how do i get it off with out going to autozone and renting a slide hammer.
I love it when people say "You don't even have an engine in that car want-to-be!" but i say" Yeah well lets see yours get 50mpg"
PostPosted: Tue Mar 22, 2005 8:49 pm
a.k.a Bum head
In two words: you don't. You need the slide hammer and there's nothing you can do about it.
Make sure that you have your hub nut unstaked and removed first, or else you'll just be hammering away for nothing.
Be careful putting the hub back in or else you'll push the inside wheel bearing back out the other side of the spindle. Don't use a slide hammer when reassembling. Use a large socket and a hammer instead since it's easier to keep the hub centred.
Be prepared to remove the whole spindle in case a bearing does pop out.
Chris
ps: Hopefully you've got the right rotor for your car. The larger GTi/convertable rotors won't work with the rest of the '89-94 models. Make sure you check and compare before doing major surgery on your car. :D
Good stuff for sale!
PostPosted: Tue Mar 22, 2005 11:09 pm
Is this the metro you're trying to sell? If so, why add more parts to it?
- MPGuino
PostPosted: Wed Mar 23, 2005 12:57 am
No, i sold that metro for 700 dollars, i bought an xfi for 200 and it only has 31k on it and it needs new brakes.
PostPosted: Thu Mar 24, 2005 4:58 pm
That slide hammer works like a dream when getting those rotors off. Get it. You won't regret it.
Josh
"Always remember that in the equation for drag, velocity is squared."
1993 Geo Metro Hatchback
1996 Impala SS
1980 Yamaha Maxim 650
PostPosted: Thu Mar 24, 2005 7:25 pm
Josh
Yeah, it's not much effort to get the hub to separate, but it does take some persuasion. I just removed my knuckle completely from the car, and then tapped the hub out from the backside while the knuckle was clamped in a vice.
- MPGuino
PostPosted: Fri Mar 25, 2005 4:45 pm
Piece of 2x4 and a hammer. Put the 2x4 behind the rotor and hit the board with the hammer all over the place. I did it to the 89 metro my parents have. 189K miles on there and never been off. The board and hammer works like a charm. Just be sure to hit it all over.
-- Don --
The G10, Suzukis way of natural traction control.
This is my hooptie, there are many like it but this one is mine. With out my hooptie I am walking and without me my hooptie is broken down.
