It is currently Fri Oct 20, 2017 5:50 pm
PostPosted: Mon Feb 04, 2002 2:02 pm
I am looking for an aftermarket tachometer that will work with my 3-cyl Metro. I would like on that I could mount on my dash and has a 3" face (maybe larger or smaller). I cannot seem to find them anywhere. <p></p><i></i>
PostPosted: Mon Feb 04, 2002 3:34 pm
Ooh Ooh Pick me. Pick me.<!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> I have a Sunpro Tach that I got at Advance Auto Parts where I work. It is a 3 1/2" tach with a white face. It is compatible with 3,4,5,6,8 cylinder engines and even has an internal shift light. Check out my homepage at...<!--EZCODE AUTOLINK START--><a href="http://hometown.aol.com/rallymetroxfi94/">hometown.aol.com/rallymetroxfi94/</a><!--EZCODE AUTOLINK END--><br>There is a semi-good pic of it in my interior. Oh yeah and the price on it was $99.99.<br><br>Chris <p>Why a Metro? Because the looks on peoples faces are priceless.</p><i></i>
PostPosted: Wed Feb 13, 2002 2:52 am
I've just stuck a GTI gauge set in my 3 cyl swift. A simple un-plug old, plug-in new job, but the tacho runs slow - not surprising I guess since it's expecting to see pulses from a 4 cyl engine.<br>Does anyone know of a wiring mod to make it read correctly? The manuals are a little lean on hard info for this type of thing. Any help would be much appreciated <p></p><i></i>
PostPosted: Thu Feb 14, 2002 1:37 pm
A gauge set from a Metro Convertible has the right tach for a 3 cyl. engine. <p></p><i></i>
PostPosted: Sat Feb 16, 2002 7:05 am
And would you have one for sale to an old digger?<br><br>Thanks<br><br>Dunk - dunk@dunkworld.com <p></p><i></i>
 Post subject: three cyl. tach
PostPosted: Wed Feb 27, 2002 11:48 pm
There is a gauge set on ebay right now with the tach in it for the 3 cyl. it was at 53 plus 15 shipping last time i checked and thats not bad i just paid 75 at the local junkyard today cause i didnt wnat to wait puting it in tommorrow oh yea<br><br> <p></p><i></i>
PostPosted: Thu Feb 28, 2002 1:19 pm
don't know about a wiring mod, but I am putting a G13B in my 96 Metro. for now the gauge cluster from a 94 GT works great, don't notice any slowness in the operation of the tach though. - regards, Sean <p></p><i></i>
PostPosted: Mon Mar 04, 2002 2:46 am
Well, the mechanics across the street ran it up and it was reading 2100 revs at an actual 2700, according to their diagnostic machine.<br>It's not a big problem but it would be nice to have it accurate<br><br>Dunk<br><br>dunk@dunkworld.com <p></p><i></i>
PostPosted: Wed Dec 18, 2002 11:16 am
If you are a real tight wad (like me), try this. I do this on oil gauges with the dumb “L” and “H” marks and it will work for your tack too. You know the gauge is reading 3/4s times slower. Simply spray paint the face and use press on numbers and pin striping from an art store to redo the display. Interpolate where the new marks should be. With oil pumps you can use a bike pump or whatever with a gauge. Add 10lbs of air each time and mark off the dial face. When done, you have a nice looking gauge that is calibrated with real numbers or in your case, the correct rpm spacing. One advantage of using your gauge is there will be room for a higher rpm range. <br><br>Do note that you will be very luck to find press on numbers/letters that match at an art store. <br> <p></p><i></i>
 Post subject: GTI Tachometer for 3-cyl
PostPosted: Wed Dec 18, 2002 12:53 pm
Aftermarket tach is easy. If you buy a standard Autometer tach. You send it to them and they will calibrate it for you and send it back to you. But only the Autometer ones not Autogage. Yes, even the monster tach.<!--EZCODE EMOTICON START :hat --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Wed Dec 18, 2002 7:54 pm
banned
hey dunk world, there is an easier way to fix your 3cyl/4cyl reading tach problem, firstly, you get some 1300 axles, then a 1300 engine, then you drop it in and fire it up and your tach will work accurately!<!--EZCODE EMOTICON START :p --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/tongue.gif ALT=":p"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Fri May 19, 2006 8:55 pm
Found mine on neonedge.com. Works for 3,4, and 6cyl.
PostPosted: Fri May 19, 2006 9:51 pm
NEW RECORD!!! A 4-year old thread bump!!
<b>THANK YOU Wagon, T3Ragtop, and Casey for getting us home.</b><p>
PostPosted: Fri May 19, 2006 10:38 pm
Teamswift Street Pharmacist
can somebody shoot him?
I'M DRIVING A LADA NOW!!!
