It is currently Sun Feb 25, 2018 11:08 am
PostPosted: Sat Sep 17, 2005 2:26 am
Thank you to those who posted some info regarding removing the O2 sensor. Now, I have another question. The service manual says start up and warm the car to operating temp and then remove the sensor. Can the sensor be removed from a cold engine? Which way is best? Should I spray the connections first with some type of lubricant such as Blaster, et. If there are any other tricks please let me know.
Kent
Kent
PostPosted: Sat Sep 17, 2005 2:36 am
Fire, Liquid Wrench and impact gun are my choices for unseizing stuck parts. Instead of warming the engine up, you can apply localized heat from a torch. Liquid Wrench works better than WD-40, and it's also non-flammable with is really nice when you're simultaniously using a torch.
PostPosted: Sat Sep 17, 2005 8:41 am
Sparky
I sprayed a little Liquid Wrench on the sensor and then used used a Long Box end wrench to get it out. Did not have anywhere near the nightmare I expected. :twisted:
PostPosted: Sat Sep 17, 2005 11:39 am
i didn't need heat at all when i changed mine - lots of liquid wrench worked, first try.
also, i broke the end off the old sensor with a hammer so i could use a regular depth socket.
... www.EcoModder.com
PostPosted: Sun Sep 18, 2005 5:58 pm
Vise grips and my mini channel locks are my o2 sensor tools. :)
-- Don --
The G10, Suzukis way of natural traction control.
This is my hooptie, there are many like it but this one is mine. With out my hooptie I am walking and without me my hooptie is broken down.
