It is currently Mon Jan 22, 2018 12:24 am
PostPosted: Sun Aug 13, 2006 12:25 am
Dash lights come on whiel turning left. It seems when I take a left hand turn my hand break light comes on on my dash. I am aware that my hand brake is loose and I'll tighten that tomorow but the light comes on when I take a left turn and I'm wondering if its just a sensor or if its the line being caughbt/manipulated... any ideas?
PostPosted: Sun Aug 13, 2006 1:59 am
I remember this coming up before, I'm pretty sure it was something with the switch on the brake lever.
http://www.paypalsucks.com
Never leave money in your account, only pay with credit card
PostPosted: Sun Aug 13, 2006 5:08 am
Brake light coming on in left hand turns is usually the low fluid sensor. Don't put brake fluid in it, the reason it is low is because you need front brake pads. When you replace them, the fluid level will rise back up.
PostPosted: Sun Aug 13, 2006 6:22 am
:werd:
You'll likely see it flicker more as time progresses. Go check the brakes.
PostPosted: Mon Aug 14, 2006 12:17 am
hmm, my did start to flicker on hard left turns but i've never seen it flicker since putting on new pads. I don't remember where I heard about the e-brake lever switch but I guess it has nothing to do with that.
PostPosted: Mon Aug 14, 2006 11:40 pm
Well I haven't noticed my breaks being in a bad condition at all... do I need to change them? or is it just a good idea and I should do it just in case?
GM's GO-CART:
1996 PONTIAC FIREFLY
Sadly enough, stock for now
Sorry if there are any spelling mistakes.
I try to spell check all posts, but I am not a dictionary.
If you must comment on my grammar, ensure that you are perfect, and then do so politely.
Cette façon la vous ne détachez pas comme un espèce de connard. Thank you
PostPosted: Fri Sep 29, 2006 8:15 pm
back breaks are fubar. Im replacing them this weekend. the front have 30% left so I'll hold off.
GM's GO-CART:
