It is currently Fri Oct 20, 2017 7:10 pm
 Post subject: ECM Keeps Blowing
PostPosted: Tue Oct 03, 2006 11:36 am
Hi Everyone:
I own a 1989 GTi Suzuki Swift. Specs: DOHC 1.3, (4 Cyl.) Fuel Injection, Electronic Ignition, Automatic (I know, automatic sucks). Great car! Cheap on gas – basically rebuilt/replaced several engine components. Very easy car to work on.
Problem as of late: Dreaded electrical. Car crapped out one very wet night. Discovered no spark – process of elimination – usual stuff: Ignition (and components), distributor cap (entire piece), etc. ……. Long and short – buddy suggested replacing the ECM (Electronic Control Module – THE BRAIN) – got one at the wreckers $65 (wasn’t easy to find (AT FED 33920-64B). Got spark - Car worked for one month.
Okay, maybe a bad ECM at the wreckers. Finally found and bought my second used ECM (tough time again). Same thing – car conked out 3 weeks later. I think there are no more ECM’s available in my country (Canada) – I bought them all (ha! ha!)
Checked out original ECM, no indication of noticeable burnt resistors. Checked out first unit purchased at wreckers, same thing – nothing noticeable.
Totally depressed and baffled as to what my next steps are. I removed the battery cables for ½ hour to reset the ECM unit (Is this right?). If the reset does not work – what are my next steps? Any help or ideas would be greatly appreciated.
PostPosted: Tue Oct 03, 2006 12:28 pm
banned
another bolton boy :) same avatar too :? hehe just wanted to say hi basically :P
CURSE MY ENEMIES FOREVER LETS SLIT OUR WRISTS AND BURN DOWN SOMETHING BEAUTIFUL.
PostPosted: Tue Oct 03, 2006 4:57 pm
It sounds like you have a wiring problems somewhere. Check the MAF wiring where it crosses by the alternator belt. Alternator belts have been known to chew through the MAF harness, short it out and kill the ECU.
PostPosted: Wed Oct 04, 2006 8:42 pm
abby normal
Here is something similar...
http://www.teamswift.net/viewtopic.php? ... ng+harness
PostPosted: Wed Oct 04, 2006 9:54 pm
You should go back to the wreckers and get the AT ecu wiring harness. Or better yet, get both harness from the cars you got the used ecu.
I'm amazed you even got your hands on 2 of these AT ecu's. :shock:
And as Lithan said, check your MAF and the wire that goes to it.
Also check for all your grounds.
Good luck.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Thu Oct 12, 2006 1:39 pm
Definitley sounds like a harness issue with the main engine harness. WIthout having witnessed the problem personally I cannot say 100%, but I would check the harness over to see if wires are exposed and check the harness at the igniter. If all checks out it may not be a bad investment to get a new harness.
I have a wire harness for a 3cyl, but nothing for a 4 banger. If your local I can go over the harness with you and tell you what your next step should be.
Users browsing this forum: Majestic-12 [Bot] and 0 guests
