It is currently Tue Feb 20, 2018 12:34 pm
PostPosted: Tue Feb 13, 2007 9:14 am
i am trying to remove as much weight as possible.
i am trying to remove the heater box from the car, i got the screws/bolts removed from the frame of it but...
what are the 2 lines going into the back ? how can they be removed OR how can i leave then and remove the box inself ?
got into a job a little to big, i thought i could just unbolt the box and remove it.
thanks for any info !
2000 chevy metro 1.0L
pjanebjane@aol.com :shock:
PostPosted: Tue Feb 13, 2007 9:50 am
Is your car or did your car have A/C?
If so those 2 lines you are referring to ar your A/C refrigerant lines.
If NO A/C then those 2 lines are the connections to the heater core.
Things that go "BOOM" in the night ! Hopefully not the 1.0.
Member#3307 ??
PostPosted: Tue Feb 13, 2007 10:07 pm
no ac, so its heater core, what inside ? can they be removed, dumb question i'm sure but i've never disected a car before...
thanks for the responce.
PostPosted: Tue Feb 13, 2007 10:51 pm
Yes, you can remove the lines from the core and remove it.
Then you need to block off or re-route the hoses in the engine bay that used to connect to the heater core.
You will see the two hoses coming out of the fire wall in this picture. One of my hoses has the Temperature gauge hooked into it. (I did a little custom work to be able to use an aftermarket gauge).
http://i88.photobucket.com/albums/k180/ ... 0_0730.jpg
After you disconnect these hoses, you can cut them and hook them together using 2 hose clamps and a small brass nipple from a hardware store.
:D
Member#3307 ??
PostPosted: Wed Feb 14, 2007 7:36 am
I wouldn't block them off, I think they act as a bypass to allow coolant to circulate when the thermostat is closed. Connecting them together is fine.
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
PostPosted: Wed Feb 14, 2007 7:43 am
I wouldn't block them off either. I would re-route/connect them together.
Member#3307 ??
PostPosted: Wed Feb 14, 2007 8:08 am
DONT DO THIS! (search for my overheating thread for the full story). Basically just connecting the hoses together creates a low resistance path for the coolant, which results in poor circulation through the cooling jacket of the engine. End result is overheating. Plugging the lines is 100% ok, as is connecting the hoses while inserting some type of restrictor.
2009 Cannondale Rize
PostPosted: Wed Feb 14, 2007 8:19 am
got it i think i'll just leave them in place and move on to the next project. thanks.
PostPosted: Wed Feb 14, 2007 8:58 am
OK, I won't do it. I'm looking at the diagram right now. Wouldn't too much flow in the heater circuit result in poor circulation through the radiator, not the jacket? Same result anyway... :?
PostPosted: Wed Feb 14, 2007 10:10 am
Sorry, yes, that's what I should've written... same difference.
