It is currently Mon Feb 19, 2018 11:39 pm
PostPosted: Thu Dec 27, 2007 11:12 pm
Can anybody tell me what year this motor number is? G13P100682 on exhaust side of motor. I was thinking it was a 1993 because of the "P" but several wire colors do not match the 93 wiring diagrams that I have. I bought the motor with a complete wiring harness. Tks Russ
PostPosted: Fri Dec 28, 2007 1:10 am
What does the intake manifold look like?
• 1989 (EFI badge is bolted on with socket headed screws, PCV valve is bolted to intake plenum)
• 1990 - 1991 (EFI badge is now glued in place, PCV valve is bolted to intake plenum)
• 1992 - 1994 ((EFI badge is glued in place, PCV valve is fitted to valve cover, intake plenum has a flared nipple fitted to it)
PostPosted: Fri Dec 28, 2007 2:26 pm
The badge is glued. There is a black rubber hose running straight from the plenum to the valve cover and a blue plastic barbed fitting with the #641300 engraved on it at the valve cover. Is that the PCV? If so then it is a 93. Wonder why the wire colors don't match the diagram. Any idea where to find a CHEAP or FREE factory diagram? I am using a Mitchell diagram, Russ
PostPosted: Sat Dec 29, 2007 1:03 am
The GTi Index that is Stickied in this section has links to a few wiring diagrams, but they're all for MK2 vehicles.
