It is currently Thu Oct 19, 2017 11:58 am
 Post subject: driveshafts
PostPosted: Tue Feb 12, 2008 7:54 pm
Need to know if theres any difference between the splines on the driveshafts of a mk1 and a mk2/3? Are the splines different inside(gearbox side) and outside(wheel end)?Also are the hubs on the mk1 and the mk2/3 different(sizes and specs)? Have got a mk1 gearbox on a mk2 car/engine and need shafts to fit.
Thanks in advance
PostPosted: Wed Feb 13, 2008 1:54 pm
Main twit
heres the low down...
all 3 cylinder shafts be it mk1,2,3 are the same... inside tranny and outside on hub.
GT shafts mk1,2,3 are the same inside tranny as the 3 cylinders but the outter spline at the hub only fits the GT brakes.
Tim
MT Motorsport
www.mtmotorsport.ca
PostPosted: Thu Feb 14, 2008 1:07 am
I'll add to that, the mk1 non gti has the smallest size outer cvs, the mk1 gti and mk2/3 non gti outer cv's are slightly bigger but the mk2 non gti shafts are slightly longer (might be 15mm, cant remember) than a mk1 gti shaft and the seal on the back of the hub is different than mk1gti hub.
The mk2/3 gti and 1600 hubs have the biggest outer cv's but the 1600 shafts also have a bigger inner cv and different spline into the gearbox.
PostPosted: Thu Feb 14, 2008 6:36 pm
Hi,
Mk1 Gti has 1 less splines than mk2.
Are you fitting Gti engine into Mini in UK!?
I have made mk2 driveshaft with mini hub end and it will fit P/S but not driver side.
If you want see it, and live close to Durham let me know.
I can show you my '68 Mini with Gti engine in progress(or luck of...)
Stop laughing Dattman!
Cheers
Atchi
PostPosted: Fri Feb 15, 2008 3:18 am
miniswift wrote:
Hi,
Atchi
A mk1 gti and mk2 SOHC are the same size, the mk2gti does indeed have one more spline and a bigger OD, I know this as I fitted a mk1gti cv onto a mk2 sohc shaft and fitted into a mk2 sohc hub only to find the seal was different.
Atchi I'm not laughing now that I know I could of used mk2 sohc shafts on my mini project, pity I threw them out :thwack:
 Post subject: Re: driveshafts
PostPosted: Tue Aug 19, 2008 11:47 pm
I have a 1988 chevy sprint, and I am using both driveshafts out of a 1994 geo metro. I had to remove the main grease seal on the steering knuckles but since the knuckles have two wheel bearings each, and the bearing's grease seal is facing out, it should be o.k. Good to know when you are short on cash and the junk yard has a nice mk2 metro with good axles.
PostPosted: Tue Aug 19, 2008 11:55 pm
'94 is a Mk3, but still are the same.
Project Page
Image Image
PostPosted: Thu Feb 17, 2011 11:22 pm
is the manual transmission from 93 gti swappable to 96 swift with auto trans? thanks, ive been searching but to no avail, i cant find any detailed info about this and specific parts im gonna need if im going on this route....
