It is currently Sun Oct 22, 2017 1:47 am
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2  Next
PostPosted: Thu Jan 09, 2003 6:40 pm
Senior Swift Guru
This thread will stay along the top bar of this section. <br><br>For those who have forced induction examples to be shared, please post your links in here. When somebody wants to get a few ideas or check out what has been done they have a place to go.<br><br>My old nitrous set-up in detail.<br><br><a href="http://www.angelfire.com/de/ksj/nitrous.html">www.angelfire.com/de/ksj/nitrous.html</a><br><br>My current Turbo page is in my Signature.<br> <p>-Kyle Jones <a href="http://www.angelfire.com/de/ksj/myswift.html"><br><strong> Junk-Yard Turbo set-up, formerly NOS-fed, constantly evolving 1989 Suzuki Swift GTi</strong><br></a><br></p>
PostPosted: Thu Jan 09, 2003 8:07 pm
Here 's my site Mitsu TD05H-16G turbo <br><br><!--EZCODE AUTOLINK START--><a href="http://groups.msn.com/swiftturbo">groups.msn.com/swiftturbo</a><!--EZCODE AUTOLINK END--> <p></p><i></i>
PostPosted: Fri Jan 10, 2003 5:49 am
My JunkYard setup with added Garret T25 and IC from saab 9000 turbo, bypassvalve bosch(saab). 0.45 bar in 10.000 US-miles problemfree. Works wery well, in need of harder clutch, then more bar/psi with added fuel. Totaly stock engine and fuel today.<br><!--EZCODE AUTOLINK START--><a href="http://photos.yahoo.com/swiftanders">photos.yahoo.com/swiftanders</a><!--EZCODE AUTOLINK END--><br> <p>_________________________________________<br>Andypandy, the Swede.<br>Audi 100 Turbo, fast!<br>Swift GTI Turbo, not so fast... yet</p><i>Edited by: <A HREF=http://pub83.ezboard.com/bteamswift.showUserPublicProfile?gid=anordman>anordman</A> at: 1/10/03 4:59:34 am<br></i>
PostPosted: Fri Jan 10, 2003 9:38 am
Mine setup is sort of junkyard too (inspired by Kyle)<br>Gonna add some more of my setup pics soon.<br><br><!--EZCODE LINK START--><a href="http://groups.msn.com/BoostingGti" target="top">groups.msn.com/BoostingGti</a><!--EZCODE LINK END--> <p></p><i></i>
PostPosted: Fri Jan 10, 2003 7:00 pm
Boosting GTI... How about some specifics what turbo, IC, injectors, fuel etc? <p></p><i></i>
PostPosted: Sat Jan 11, 2003 7:17 am
Georges44,i use a mitsu 15g with a GReddy manifold,as you many would know GReddy doesn't make anything for suzuki,and NO it's not costum made either but costum fitted.For now stock injectors for 10-12psi of boost,chopped fuel rail works like a wonder, Aeromotive fuel pressure regulator just like yours.<br>Intercooler i'm not sure but i think it's off an 300zx and i use a DSM blow off valve.Everyting else is stock,stock ECM,no piggyback,apex safc coming soon tough.<br><br><br> <p></p><i></i>
 Post subject: Oil pressure gauge
PostPosted: Sun Jan 12, 2003 5:51 pm
anordman: I see you placed an oil pressure gauge, but I really wouldn't hook it up where you did. Measure oil pressure AFTER the oil filter, not before the filter, if the filter would become restrictive you would see a higher pressure rather than something alerting. <p></p><i></i>
 Post subject: Re: Oil pressure gauge
PostPosted: Mon Jan 13, 2003 4:40 pm
That i realized the first day. "What if my filter get stuck, i would not see it", was my thaught (beside the higer pressure, that i was aware of). I changed place wery next day whith my own added oiltempsensor. Now measuring the pressure in the end of cylhead, and temp after oilpump. So the pics is lying, i know. (Have to take new photos...) <p>_________________________________________<br>Andypandy, the Swede.<br>Audi 100 Turbo, fast!<br>Swift GTI Turbo, not so fast... yet</p><i></i>
 Post subject: Plugs in oil path
PostPosted: Mon Jan 13, 2003 6:05 pm
I love the fact that this engine has a lot of plugs in the oil path, so it's easy to do various things to the oil system, monitor temperatures and etcettera. You could also easily add an oil cooler. Remove the oil pump, tap and plug the oil path from the pump to the filter, put oil pump back in place, install an oil filter mount close to the engine along with an oil thermostat, run a line from the plug on the pressure side of the oil pump to the filter, then through the thermostat back into the 1/2" pipe the oil filter used to screw on. Connect oil cooler element to the thermostat and you're pretty much set.<br>A dry sump system would also be easy to implement, basically remove the sump pipe from the oil pump and plug the hole it connects to. Get a metal tank for the oil, at least the capacity of the oil pan, larger is probably not worse. Run a line from the bottom of the oil tank into the oil pump intake and install an external pump to take oil from the oil drain plug on the oil pan, and back to the oil tank, and you have a dry sump system.<br><br>On an unrelated note, I got a thermometer today. It's actually a controlling unit for a refrigeration system and will read temperatures up to 600 degrees Celsius from PT100 sensors. I got one 600 degree sensor, think that will suffice for exhaust temperature? Installed another sensor in my oil pan. Will be installing sensors in cooling water, intercooler water, air at filter, air from turbo, air after intercooler, oil after turbo and maybe some more. <p></p><i></i>
 Post subject: SSGTI Turbo / Sweden
PostPosted: Thu Jan 16, 2003 3:36 pm
I made an small english version of my site..., just for you http://www.straffe.nu/old/urban2.html
 Post subject: Re: SSGTI Turbo / Sweden
PostPosted: Fri Jan 17, 2003 1:19 am
wow, that's quite the car. i like the wheels & fender flares you've made to fit them are they 7+ inches wide ? what sort of lights are those you've fit into the bumper ? that's a really classy little car. <p></p><i></i>
PostPosted: Fri Jan 17, 2003 4:06 am
Thanks.. <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> Im quite happy with the result myself. The whells are 16"x7" with 205/45 tires. Those lights in the front is standard equipment at my model. But I really dont think they are that nice though. The front bumper will be replaced with an rebuilt bumper from another model (the blue one showed on my site). I have to do this to be able to fit my new intercooler. Take a look at it here: <!--EZCODE AUTOLINK START--><a href="http://www.straffe.nu/ny_ic.jpg">www.straffe.nu/ny_ic.jpg</a><!--EZCODE AUTOLINK END--> <p></p><i></i>
PostPosted: Fri Jan 17, 2003 11:42 pm
ya, i found some more mark1's w/ those same lights in the bumper, just looked like those newer prelude headlights mounted upside down. <p></p><i></i>
 Post subject: Turbo setup
PostPosted: Thu Jan 23, 2003 1:18 am
MIJERZSWIFT:<br><br>Did you get any mail? Sent to MIJERZMIDAANMK@HOTMAIL.COM Right? <p></p><i></i>
 Post subject: got it !1
PostPosted: Fri Jan 24, 2003 9:06 pm
thanks runbag your the mann! @ what psi did you run for that 1/4mile run <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <p></p><i></i>
 Post subject: mijerzswift
PostPosted: Sat Jan 25, 2003 7:34 pm
I ran just about 14.5 psi <p></p><i></i>
 Post subject: Re: My little site
PostPosted: Mon Jan 27, 2003 11:49 am
Hey boys i made a little site for now,check it out.<br><br><!--EZCODE LINK START--><a href="http://www.angelfire.com/extreme4/suzukiracing/index.html" target="top">www.angelfire.com/extreme4/suzukiracing/index.html</a><!--EZCODE LINK END--> <p></p><i></i>
PostPosted: Mon Feb 10, 2003 2:19 am
Hey guys<br>I just retired my turboed gti, the stats are as follows:<br>-T3 turbo<br>-custom tuned length manifold<br>-34mm turbonetics external wastegate<br>-550mm by 300mm intercooler<br>-2 1/2inch exhaust<br>-300cc injectors<br>-malpassi fuel reg<br>-bosch fuel pump<br>-custom surge tank<br>The motor is was rebuilt from bottom up<br>-1.6 pistons<br>-shot peened rods<br>-balanced and linished crank<br>-custom enlarged oil pan<br>-o ringed block<br>-graphite head gasket<br>-race ported head<br>-3 angle valve job<br>-cc'd chambers<br>-and new everything!<br>-11mm eagle leads<br>-Super afc<br>On 10 psi my car was neck to neck with my cousins valiant pacer which ran a 13.1@105mph. On 15psi i beat a 12 sec R33 GTR V-spec on the roll while frying tyres in third gear. I'm getting pictures of the car scanned very soon so i'll e-mail them to anyone interested. Incase you're wondering who done the work on this car then not worry as i done everything(apart from the motor) myself. I run a part time business called S&S Automotive and we deal in turbocharging and i've turboed 4 GTi's. The motor was built by my friend who is a proffessional engine builder by trade, but i've learn't how to build the engine myself now. The engine is now for sale but i stripped it down and have rebuilt myself but with the addition of Ross forged pistons running 8.0:1 comp. Anyone interested then you can e-mail me at geovoutsas@hotmail.com. <p></p><i></i>
PostPosted: Fri Mar 21, 2003 5:30 pm
Anders (anordman), jag undrar om du skulle kunna ge mig lite tips angående en turbokonvertering av en Swift GTi.<br><br>Maila mig =) :<br>brother_david@hotmail.com<br><br>Hade fint<br>-David <p></p><i></i>
PostPosted: Tue Apr 01, 2003 10:58 am
Hey runbag, nice setup.<br>What compression are you running? What kind of pistons and other internals?<br>What octane gas?<br>What kind of engine management/fuel delivery?<br><br>Baldur <p></p><i></i>
PostPosted: Sat Apr 05, 2003 4:46 pm
Thanks <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>The internals is 8,5:1 forged JE-pistons and shotpeened stock conrods.<br>I'm using 98 octane unleaded fuel, and stock management/fuel delivery together with an piggyback ECU (4 extra injectors).<br> <p></p><i></i>
 Post subject: Turbo GTi
PostPosted: Wed Jul 09, 2003 9:38 am
I am creating a turbo GTi i built it before but i cracked a piston so i'm rebuilding it for beter reliability here is my list;<br>1) 1.6 vitara pistons <br>2) galant vr-4 intercooler<br>3) 380cc or 365cc injectors from toyota 4AGZE<br>4) straight through exhaust system 2.5" pipes<br>5) ACT clutch street (may upgrade to 4-puc and ACT <br> Pressure plate)<br>6) Microtech LT-8 fuel & timing computer<br>7) mitsubishi BOV<br><!--EZCODE EMOTICON START 8) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"><!--EZCODE EMOTICON END--> Aquamist Water injection <br>9) B&M oil cooler<br>10) Nissan SR20 Throttle body<br>11) Garrett T28 Turbo<br><br>My concern is that i want to achieve a max of 15lbs of boost for now, i want to know if the stock con rods are strong enought to handle this pressure, also if the stock Main & Conrod bearings are good enough also.<br>the body is still stock looking but i will have to deal with that later when i get some more money.<br><br>Please tell me what you think <p></p><i></i>
 Post subject: Re: today
PostPosted: Mon Sep 01, 2003 9:36 pm
yow hugh, i saw a gti being tuboed today out by king midas muflers!<!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <br><br>the suzuki gods got in me and something just made me drive out there, i see the gti up on the ramp with the turbo and manifold on the ground, tools and hoses all over the place<!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <br><br>i almost fainted<!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <br><br>im going to turbo the next gti i get, if this guys own survives ill do exactly the same, his is as simple as they get!<br><br>stock engine, ihi turbo, 5psi, everything else stock!<!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <br><br>im going to spend about 20k(jamaican) and do a simple set-up, use larger injecters, and run 5psi with stock rev limit, i think the car should last!<br><br>im going back tomorow top see the final result, i hope it doesnt blow up<!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> <br><br>i didn't know these cars were so easy to turbo!? or are they<!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Thu Sep 04, 2003 4:07 pm
I just made a first pass at building up a Suzuki turbo link page. I was getting sick of the dead links and such I was finding on others pages. I tried to include all of your pages. I hope that is OK. <br><br>Please let me know of any bad links, or links that need to be added.<br><br><!--EZCODE LINK START--><a href="http://rz-products.com/WAYNE/UPDATES/turbo.html">The Suzuki Turbo Link Page.</a><!--EZCODE LINK END--><br><br>Thanks,<br><br>-Wayne <p></p><i></i>
 Post subject: Mitzuki
PostPosted: Fri Sep 05, 2003 3:24 am
Nice little Mitzuki you got there. With the weight of these Samurais and the power of an eclipse (although the mitsu cast steel blocks are heavy) it must really just fly. <p></p><i></i>
