It is currently Sat Jan 20, 2018 10:34 pm
PostPosted: Tue Sep 30, 2003 4:48 pm
Where do I have to install my oilpressuregauge in the engine ?!
A pic woul'd realy be a great help ! :D
PostPosted: Tue Sep 30, 2003 7:12 pm
banned
it should be at the front of the engine! by the oil filter,, beside it
PostPosted: Tue Sep 30, 2003 8:11 pm
remove that big sheet metal heatshield that sits beside the radiator, you should then have a clear view of your oil filter, and the oil pressure switch (the wire when grounded lights up your low oil pressure light on your dash).
Removing your oil filter will give you better access to the pressure switch. If you're using an electric Autometer oil pressure gauge, the sending unit threads directly into the pressure switch hole without requiring any adapters. When I installed mine, I chose to run a braided stainless steel line and I put a T-fitting on the end to accomodate both the new sending unit and the stock pressure switch. If you're using an electric sending unit check with a multimeter that you have good continuity between the sending unit housing and the negative battery terminal (because I used a stainless line, It was already grounded with only 1-2 ohms of resistance). I have pictures of my own oil pressure gauge installation, but haven't scanned them yet. Here's a page from the service manual how to check for oil pressure from the oil pressure switch.
PostPosted: Wed Oct 01, 2003 4:41 pm
made a pic,just plug the original (with the yellow wire) out,and than plug the uther one in it? Cant harm if the other one is out ?
PostPosted: Wed Oct 01, 2003 4:49 pm
About the oiltemprature ...
I plugged it in the side of the head as U can see (the black thing),but it stays a bit low I think,never came above 100 degrees ..
Shall I put it somewhere else ?!
PostPosted: Thu Oct 02, 2003 7:53 pm
yes the device with the yellow wire is your pressure switch. This is where you can install your oil pressure gauge (or electric sending unit). If you remove the pressure switch, something must fill the hole (either a gauge, pressure switch, sending unit, or just a bolt to plug it) as pressurized oil comes into physical contact with the pressure switch. If you don't put something in the hole your oil pump will use the opening to purge your oil! :shock:
PostPosted: Thu Oct 02, 2003 8:23 pm
hey i've got an extra electronic oil pressure gauge from my old volvo, can it be hooked up to the oil pressure switch as well ??
 Post subject: Re:
PostPosted: Fri Sep 05, 2008 11:04 am
Is it just me or does the exhaust manifold on this DOHC look like it only has 3 outlets?
And NO, I do not have cataracts. :D
Things that go "BOOM" in the night ! Hopefully not the 1.0.
Member#3307 ??
PostPosted: Fri Sep 05, 2008 10:55 pm
I used the control, Mouse Wheel to enlarge the picture of the Engine... It looks like there is an exhaust port under the black thing by the camshaft belts on the left side of the engine.........................
Dale
PostPosted: Sat Sep 06, 2008 11:25 am
That's the engine mount - the "missing outlet" is #4 and it's there behind the radiator mount - it just looks that way because of the angle the picture was taken from.
'93 1.3 Swift GLX
'98 2.0 Grand Vitara
PostPosted: Wed Sep 10, 2008 10:15 am
That's a relief, I thought I was losing my mind..... :)
Member#3307 ??
