It is currently Thu Oct 19, 2017 8:08 am
PostPosted: Fri May 09, 2003 7:35 pm
i changed my brakes today. had my wife pump the pedal with the bleeder cap off untill it squirted out constantly. had her hold ity down while i tightened it. i did it on all 4 corners, went for a test drive and drove into the bushes on the side of my house<!--EZCODE EMOTICON START :x --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/sick.gif ALT=":x"><!--EZCODE EMOTICON END--> . did i not do it right?<!--EZCODE EMOTICON START :\ --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/ohwell.gif ALT=":\"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Fri May 09, 2003 8:51 pm
you have to get her to pump the pedal while the bleeder screw is tight ... then have her hold the brake pedal down and realease the bleeder screw for about 5 seconds .. then retighten the bleeder screw and have her pump them again and reapeat untill she feels the pedal is at a good spot .. Hope that helps .. <p>chadiator@hotmail.com</p><i></i>
 Post subject: brake bleed
PostPosted: Sat May 10, 2003 2:38 am
Be sure to check the master cyl fluid reservoir each time<br>and keep it full-up on fluid.<br>If it gets any air in there, because of low fliud level,<br>you've got to redo them all over again. <p></p><i></i>
 Post subject: Re: brake bleed
PostPosted: Sat May 10, 2003 7:30 am
like chadiator said.<br><br>pump with bleeder closed about 5 times a wheel, while holding pedal to floor open bleeder.<br><br>make sure you have a hose with either a one way check valve, or a hose running to a container with the hose under the brake fluid level.<br><br>doing brakes right requires more then a few minutes.<br><br>always start with the wheel fartest away from the master cylinder.<br>do each wheel at least 2-3 times. or untill all old fluid and air gone<br>fill resivour offten<br><br>NEVER release brake peddle with bleeder open <p>MURR<br>1990 Suzuki Swift GT<br>TOY racer</p><i></i>
PostPosted: Sat May 10, 2003 1:07 pm
thanks for the replies. i did it that way and they are better but i still need to do them more as it only took me about 10min to do all 4. i'll finish up tomorrow <p></p><i></i>
PostPosted: Sun May 11, 2003 7:35 pm
glad we could help<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <p>chadiator@hotmail.com</p><i></i>
