It is currently Sun Feb 18, 2018 9:17 pm
Post new topic Reply to topic  [ 69 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Jul 13, 2004 8:06 am
All the results from the test cars have been positive. Because of the amount of PM's, and emails I've been getting, I will now make these available.
The sprockets are intended for the 3cyl. motor with the square tooth timing belt, which I believe to be pre 94. The 94-95 sprockets are also now available, and ocassionally the 96-up sprockets can be had.
They will also work on the 1.3 8V motors, prior to 95, but because of the factory valve timing, I don't recomend any more than +6, and thats only with a fairly healthy cam. If there is interest, I will make +4 sprockets for the 1.3 8V.
This is what is available.
+6, +8, +10 cam sprockets. These are modified stock sprockets.
Dyno testing by B'villetom showed a 5 hp improvement with just a +10 sprocket on a stock motor with open exhaust.
Prices are US$31.50/shipped to US or Canada for the 89-93 sprockets. Shipping is more for the other.
PostPosted: Thu Jul 15, 2004 8:48 am
DOHC cam gears? how much?
PostPosted: Fri Jul 16, 2004 11:03 am
Wait until I get results from n1tro. If the results are positive, then prices will be the same.
PostPosted: Fri Jul 16, 2004 11:43 am
we're going out to do a bunch of timed runs on some of the different settings this sunday ...
PostPosted: Fri Aug 13, 2004 8:39 pm
Where?
PostPosted: Fri Aug 13, 2004 10:31 pm
old post ;) sadly, it looks like i'm going to have to wait until i'm over on the mainland next unless someone around here (victoria) has an impact gun ..
PostPosted: Sat Aug 14, 2004 12:15 pm
To get the stock sprockets off? I knew you hadn't replaced them yet. I have access to an old timing belt if you want to slip that one on and jam a screwdriver in the flywheel ring gear.
PostPosted: Tue Jan 04, 2005 5:33 pm
ANY RESULTS ??
constantly evolving,daily driven racecar
PostPosted: Wed Jan 12, 2005 4:42 am
Is there no core charge? maybe a discount if we send you back our stock sprocket once youres is installed? Eventually you got to run out of sprockets lol.
90 Sprint supercharger in a box waiting for warm weather.
85 Fiero GT solo racer custom interior.
81 Audi 4000
PostPosted: Wed Jan 12, 2005 4:57 am
There is no core, but I'll charge you one if that will make you happy :D
The problem is that the core charge would be about what it costs to ship.
PostPosted: Wed Jan 12, 2005 5:15 am
Thanks for clearing that up.
81 Audi 4000
PostPosted: Sun Jan 30, 2005 9:04 pm
Any sprockets for 87-88 T3 engine ???? I would be interested . Its going to machine shop tomorrow , done in few days need to put it back together . Might as well have a cam gear on it if its available . 8)
PostPosted: Sun Jan 30, 2005 9:18 pm
Its not really neccesary on the Mk1 cars unless you are running lots of cam. In that case, I would go max +6
PostPosted: Tue Feb 01, 2005 7:45 pm
Check PM 8)
 Post subject: 96
PostPosted: Wed Apr 20, 2005 9:04 am
Got any for a 96 3cyl.
 Post subject: Re: 96
PostPosted: Wed Apr 20, 2005 5:47 pm
I do now.
PM me if you are interested.
PostPosted: Sun Jul 03, 2005 9:16 pm
how bout a 97 sohc 4 banger?
PostPosted: Mon Jul 04, 2005 12:30 am
If you dont have one of these, get one for your Swift :!:
PostPosted: Mon Jul 04, 2005 7:21 am
Let me do some degreeing, and see if you really need one first. Good timing, I have one of those heads on my test bench right now.
PostPosted: Mon Aug 08, 2005 3:45 pm
have you found out how the DOHC advance sprokets work and what would you recomend for a stock DOHC engine, 6 8 or 10% advance?
PostPosted: Mon Aug 08, 2005 5:04 pm
http://www.teamswift.net/viewtopic.php?t=15919
mine responded very well to them 8)
Dattman wrote:
PostPosted: Thu Sep 08, 2005 1:24 am
Perhaps this is a silly question, but couldn't you get 9° (360°/40 teeth) of advance with stock cam pulley by advancing it 1 tooth?
PostPosted: Thu Sep 08, 2005 2:42 am
that's actually works out to be 18 degrees, you need to measure by the crank, not the pulley ... (or vice versa)
been there, tried that ..
PostPosted: Fri Sep 09, 2005 6:47 am
:D Hi, I would like to purchase an advanced timing gear for a stock '97 Metro 1.0 3 cyl. Do you have one available? and what degree would you recommend for this 5speed car?
Thanks,
Jerry Headley
Union, Wa. USA
PostPosted: Fri Sep 09, 2005 5:32 pm
Thanks,
Jerry Headley
Union, Wa. USA
I have one.
$25 + $8.50 shipping in US/Canada(those ones are heavy)
I recomend the +10 for your car.
